craddockpawley
New Member
I've been driving my Wrangler for years and honestly I never really gave much thought to the chassis until I started noticing some uneven tire wear and a slight pull to one side that just wouldn't go away no matter how many times I got the alignment done. I was starting to worry it might be something serious like a bent frame or damaged mounting points from some of the off-road trips I've done, especially since I've had a few hard landings in the dunes. A mate who knows his Jeeps told me I should get it properly inspected by someone who actually knows what they're looking at, because a lot of general garages will just do an alignment and send you on your way without checking the underlying structure. I found a workshop that offers Top Jeep Chassis Repair in Musaffah and they really put my mind at ease. They put the car on a proper jig, measured everything, and showed me that it was actually just a worn control arm bushing that was throwing everything off, not a bent frame like I'd feared . They replaced the bushing, did a full inspection of all the mounting points and suspension components, and the car drives straight as an arrow now. It's amazing how much difference a proper diagnosis makes compared to just guessing and replacing parts. If you're having alignment issues that won't stay fixed, definitely get your chassis and suspension checked properly because it's cheaper than replacing tires every few months. Cheers.
